aftermarket HU install
Old Feb 16, 2009 | 09:14 PM
Mondini's Avatar
Question aftermarket HU install
will it hurt the cars computer by just hard wiring up my stereo? I have went through numerous wiring harnesses and none of them are the right ones... i have a 08 2LT... the last harness i used put my vehicle in lock mode making it so i couldn't turn it over... i dont care about the chimes or turn signal sounds... can i just hardwire it and not even worry about the harness?? plz help me out...
Old Feb 16, 2009 | 09:51 PM
masterchief1112's Avatar
my amp is hard wired so i dont see why you coundnt
Old Feb 17, 2009 | 05:29 PM
hugheshhr's Avatar
Mine is hardwired in. I cut the factory harness for the constant and ground. I also spliced into the door speakers behind the deck. I ran a switched wire to the fuse box. I think, I may have ran the constant to fuse and spliced the switched. I would suggest grounding the HU at the same location as the amp in the back. I got to move mine from the front. I got a horrible buzz noise with my new radio coming from a bad ground. Also if you hafta run RCA's run them down the middle of the car if possible.
Old Feb 17, 2009 | 06:46 PM
rca's work well on the passenger side also. moved mine to the passenger side because positive battery cable is on the drivers side in this car.
Old Feb 17, 2009 | 08:37 PM
Mondini's Avatar
Talking thanx
thank you guys for the information... i think im just goin to hard wire the HU b/c im tired of looking for the right harness lol...
Old Feb 17, 2009 | 08:54 PM
jmarines's Avatar
It shouldnt be that hard to find the wiring harness.. I just looked up on ebay and found the wiring harness and install kit for like 15.00. From what I understand, there are only two kinds of systems in our hhr, regular nonamplified and premuim, I could be wronge though about the two types.
Old Feb 17, 2009 | 09:49 PM
i think theres 3. but i could be wrong. premium, 6 speaker, and low ball. but now that i think about it there may be only 2
Old Feb 17, 2009 | 11:34 PM
ssdivin's Avatar
http://www.installer.com/cars/by_car.php?carid=6069
use the gmos lan-04
Old Feb 18, 2009 | 09:26 PM
Mondini's Avatar
wut exacly did you do?... im talking about not using a harness at all jus cutting the wires and hardwiring it all... i am afraid if i cut the wires that i wont be able to put anything in if it doesn't work... plz give me a detailed description on wut u did... thank you
Old Feb 18, 2009 | 09:45 PM
i essentially spliced in an amp inbetween the HU and the door speakers right behind the HU Im sure you could jsut splice in with a HU behind the connector back there.
cshaberts
Jun 15, 2017 08:35 AM
RDB
Aug 26, 2013 12:34 PM
onlyjds
Aug 11, 2013 12:44 PM
steveo3140
Jun 30, 2012 09:51 AM
kjlee2112
Nov 23, 2008 02:58 PM
