Location for switches
Old May 23, 2006 | 09:08 PM
Lee3333's Avatar
I found a spot to add a couple of switches (to be used for horn and ?)
[IMG][/IMG]
Who needs a light to tell me that a passanger is sitting in the front seat?
I left it plugged in behind the dash. Used a piece of 1/2 plywood, filed down the ends so the threads on the switch would stick through a little, then used sheet metal pan head screws to hold it in place. Best of all, no permanet changes made, so I can easily revert back to stock if I want to.
Old May 23, 2006 | 10:32 PM
Skatetheglobe's Avatar
The location is pretty smooth but I know there are alot of switches out there that would look better than those toggles.IMO..
Old May 23, 2006 | 11:20 PM
ng8650's Avatar
Those are standard for the smoke screen and the oil...
Ng
Old May 24, 2006 | 06:48 AM
Lee3333's Avatar
I know. It kind of gives it that raw, racing edge. The reason I had to use them is I wanted a single pole double throw switch that was center off, constant on, and momentary for the other side. Naturally, for my other SPDT switch, it had to match. I may move them under the steering column and get something more fitting the HHR interior.
My car(s) are always a 'work in progress'
Old May 24, 2006 | 06:56 AM
ah for the horn.I got you..
Old May 24, 2006 | 08:41 AM
txsman2930's Avatar
What did you do to your airbag indicators?
Old May 24, 2006 | 01:45 PM
PhxHHR's Avatar
Ng
Ahh, yes, the ol' Spyhunter routine - I can hear "Peter Gunn" in the background now.......
Old May 24, 2006 | 04:20 PM
Lee3333's Avatar
I kept it plugged in to avoid an error codes and hid it behind the dash. I dont really need to see the light telling me that a passanger is sitting in the seat and the air bag is active
taz3
Apr 30, 2015 08:27 PM
mcwllt12
Jun 26, 2014 03:43 PM
mchuntley
Jun 26, 2008 04:55 PM
HHRcheater
Jan 2, 2008 05:56 PM
dr_fosg8
Dec 3, 2007 07:12 PM
