Deck Problems
Old Apr 7, 2009 | 02:18 PM
Eric B's Avatar
Deck Problems
Okay so I go to install my Alpine 9856 today in my 06 HHR LS. I bought my adapter off of ebay and its not one of those expensive ones.. I the wiring harness and the installation kit for like $12. Yea i dont care that i lose my chimes n all that.. But basically is jus a regular harness that plugs right in to other one. So I matched all the colors up and all that, I tapped my ignition into the main 12V source so I could turn it on. Well I go to test it and turn my deck on and well had to push power to turn it on but it does that any time it first turns on after a disconnected battery, but I go to turn it up and no sound... And then shortly after my gauges start freakin out and all go to zero and my temp goes to the ( ---*F) but my odometer still works. And I shut off my car and I have to shut my deck off by holdin the power button. Im jus frustrated with it... what possibly could be my problem here???
Old Apr 7, 2009 | 03:52 PM
Rcflyboy's Avatar
Is the harness made for the HHR. When I installed my Pioneer I couldn't find a harness for my 2008 and ended up buying the onstar adapter. It sure sounds like your wiring is not correct. Your turn on /off lead and others must be incorrect. I'll check and see if I have a wiring diagram for the car when i get home.
Old Apr 7, 2009 | 03:55 PM
Rcflyboy's Avatar
See if this diagram will help. This is factory 2006 one for radio.
https://www.chevyhhr.net/forums/atta...1&d=1239137699
Old Apr 7, 2009 | 05:54 PM
FLBOIZ13's Avatar
RC j/w how do u like your door speakers and also what did u do for ur front tweets?or did u find different components
Old Apr 7, 2009 | 07:23 PM
Rcflyboy's Avatar
The Infinity 6022I are great with the power from my radio. At 2ohm they work best with 2 50 watts of power. Plus I'm currently using the stock tweeter's.
I am installing an amp that runs 50 watts rms and I am gonna get some components to replace the Infinity's soon.
Might be willing to sell the Infinity's when I do to anyone intrested.
Old Apr 7, 2009 | 11:08 PM
Eric B's Avatar
Im pry jus gunna get that nice expensive harness and be done with it... thanks for the help tho
Old Apr 10, 2009 | 02:30 PM
Eric B's Avatar
well got that expensive harness in took me no longer than 15min to get everything all hooked up and working. im jus glad to be done with it now...
Chellesimm
Mar 29, 2014 06:12 PM
celblazer
Aug 13, 2009 05:18 PM
Jeda13
Jul 15, 2008 11:58 AM
JoeCanadian69
Apr 2, 2007 09:16 PM
