Help: Using an extra fog light switch
Old Aug 3, 2009 | 03:43 PM
richie6's Avatar
I want to use an extra fog light switch to control lights that will go into the visor. I believe the switch runs a negative trigger..
I don't have traction control, so I have a blank button cover next to the fog light switch...
Any help would be great..
Old Aug 3, 2009 | 04:15 PM
Do you want them to only turn on when you switch them on, or do you want them to come on when you start the car? There is a mod that can be done so that the fogs turn on/off when the car is started/turned off.
I'm not sure what its call, but the fog switch is not on/off, it is puch-button. Always turns off with the car, but will also always need to be turned off. It also turns off with the brights.
I modified my fog switch to be on/off. I leave it on and the light turn off with the car and on with the car.
Old Aug 3, 2009 | 04:30 PM
richie6's Avatar
I would like to be able to turn the visor lights on when I want..
Old Aug 3, 2009 | 07:51 PM
Then then easiest will be a toggle switch. To do the mod I referred to, you would need get a hazard and foglight switch. The hazard is an on/off. The buttons on the switches come off and then you swap them. Give you an on/off fog light switch.
https://www.chevyhhr.net/forums/show...t=light+switch
GDZHHR
"How To" Tutorial Library
35
Sep 4, 2013 06:43 PM
silvertoy
11
May 19, 2009 09:44 AM
scrambler
Oct 6, 2008 02:53 AM
DANIELHHRREYES
Mods - Interior
Feb 5, 2008 09:09 PM
TomsHHR
South Central
Aug 8, 2006 03:51 PM
