Adding XM receiver
Old Jun 20, 2006 | 11:30 AM
kevhamner's Avatar
Adding XM receiver
I just bought my HHR this past weekend and I want to add an XM receiver to the stock 6 disc radio. The radio has the 'CAT' button so I'm think the radio must have a connection for an XM recever; correct? If so, are the wires already ran to the rear of the HHR? If so, would the antenna also already be in place too?
Old Jun 20, 2006 | 04:17 PM
jerij's Avatar
I would think the wiring is in place. You can look.
The antenna is probably not unless you have the turtle on the top back.
Of course, you can run your own antenna. The stock XM takes the usual Fakra connector (but doesn't have to be Fakra, can just be female SMB)
jerij
Old Jul 10, 2006 | 07:30 AM
DJ Koz's Avatar
I have the single disc radio. I can select xm but there is no service. I have the 1LT. Is there a way to activate it?
Old Jul 10, 2006 | 08:12 AM
EZ4U2CHere's Avatar
I noticed that on mine just yesterday. Seems like it should be fairly easy and inexpensive to add on? I bet http://www.crutchfield.com would know?
Old Jul 10, 2006 | 10:39 AM
DJ Koz's Avatar
Do I need anything in addition to what I already have?
Old Jul 10, 2006 | 10:44 AM
captain howdy's Avatar
If you didn't get XM as an option you are going to need the XM receiver and antenna.
Old Jul 10, 2006 | 01:24 PM
EZ4U2CHere's Avatar
I "think" one of these will work. Either THIS ONE "OR" THIS ONE is what you will need.
This will hook the XM directly to your factory GM radio, and allow you to control and see the stations on your factory radio.
Old Jul 10, 2006 | 02:06 PM
DJ Koz's Avatar
Thank you.
Old Jul 10, 2006 | 04:47 PM
cyberone3's Avatar
the rds one is just an fm modulator that uses the radio display but you need to use the remote that it comes with it doesn't use the built into the radio controls and the first one says not compatible with hhr radio
Old Jul 10, 2006 | 06:41 PM
EZ4U2CHere's Avatar
hmmmm..... Then it's probably just a matter of time before something comes out for it.
