New speakers
Old Mar 21, 2010 | 02:47 AM
San's Avatar
San
New speakers
I wanna put new speakers in the doors and was wondering if anybody has done this, if so how hard was it? if there is another post covering this link it if you wouldn't mind thanks everybody!
Old Mar 21, 2010 | 08:43 AM
Lars on Live's Avatar
it was easy but make sure you deaden the doors at the same time. That maks the biggest difference in my experience.
Old Mar 21, 2010 | 05:14 PM
San's Avatar
San
Did you rewire it or just use the stock wiring?
Old Mar 21, 2010 | 06:53 PM
I used stock wiring but replaced the stock amp with aftermarket.
Old Mar 22, 2010 | 12:44 AM
hugheshhr's Avatar
X2 on deadening. That is the biggest issue with the hhr doors. They have to be sealed and deadened to sound great.
As for wiring, my first install used factory, the latest I ran new wire from amp into the doors. Its a pain in butt, but doable.
Old Mar 22, 2010 | 01:35 AM
San's Avatar
San
awesome to hear i was gonna just put subs in but thought that I might as well do the doors since i have the dash tore apart anyway thanks for all the info!
Old Mar 22, 2010 | 09:21 AM
hugheshhr's Avatar
You will have to make baffles for the speakers to fit, UNLESS you have the pioneer system. The base radio has the speakers molded to the baffles. the pioneer system the baffles and speakers are two pieces. I used 3/4 inch MDF for my baffles and the fit fine, with a lil trimming to the inside of the plastic door panel. nothing major at all
Old Mar 22, 2010 | 11:11 AM
twistrman's Avatar
do you have the pioneer system. I have though about redoing the door speakers and didn't think about redoing the amp. i don't know how hard it is etc. i don't need a full system in the back and everything. i just want to look stock and get some better sound
Old Mar 22, 2010 | 11:40 PM
San's Avatar
San
I have Pioneer system. I was wanting to do sound quality comps and for shows on top of the better sounds during my everyday driving.
Old Mar 23, 2010 | 07:32 AM
I have the pioneer system
looks stock for the most part. I cut the stock tweeter location and installed JL tweeters there, and I modified the stock sub box location and put a JL sub there. I also added 2 amps in the storage are to give better power and more control over balance to the speakers. Well worth the effort in my opinion, but only after you deaden the car. It's a cheap car and rattles as is, if you add real power to the system it'll start sounding even worse.
