New B 2 HHR DID SEARCH not new to fourms
OK i tried the search button did not find anything. I just bought my 2006 2LT HHR. Well here are my questions:
(1)First location of stock amp to the "sub"
(2) Cubic size of sub "encoulser" and depth
(3) Can i and another sub next to it on that side (8")
(4) is the wiring a b!t@* ( i ask this because i used to own a firebird with the moonsoon system and i had to re-run all the wires since it wasn't as simple as a positive and negative.
(5) adding 2 amps to stock deck ( i know i need a pac i beileve right? i know we were able to do them on firebirds)
(6) is there a write up on getting through the firewall with out drilling
FIRST i am not new to stereos i can do the work my self no help needed. I dont want to make a mess on my brand new car. I also rather use the factory deck i know aftermarket is better but i would rather use stock?
Thanks
Well ok then i will have to think of another way to get bass. I dont want another huge box in my little trunk. I delt with that in the firebird. First thank you, second do you have a picture were the panel in front of the sub is taken off i really want to see what i can work with on that side. Can you think of somewhere else and i dont want much bass only like 2 8" subs. I had 2 12" JLW3 V series in my firebird and WOW. Still got em dont want to use them though. How many watts is the factory amp?
or this?
The box you see is all you have to work with. It fills the entire rear section on that side. What you see is what there is. The factory amp is weak! 260 watts peak.
I would suggest using a box and taking it out when you need the room. That's why I left my 8" after I added the box. If I have to take my box out I can hook the 8" back up so I can at least have a little bass.
Wow ok thanks alot man. The second one is what i wanted. 260 watts i can run to my back componets saves me buying a amp. So i just might go with this sub then http://www.onlinecarstereo.com/CarAu...roductID=15613 what you think? i want a little more then it has. i Mean i still have 2 12" JLs and A 900 watt rock ford for my subs and a 4 ch alpine. But tell me what you think about that sub. Also you said spacers? sorry little help on that i THINK i know what you are talking about but then i dont know?
ask cj what he did, he had some help from me on some of that stuff, but he is running 3 amps of the stock hu. he had some minor problems here and there but i think we got everything worked out, well i guess i should say he got everything worked out.
WOW nice job Capt. Did you hit your head or something?
excellent stereo info. EDIT: He'll want the link to the LT wiring diagrams.
