CB Radio Antenna location?
Old Jul 17, 2010 | 07:29 PM
2003_2LT's Avatar
I see that some of you have CB radios. I purchased one for my upcoming road trip but all of the body panels have tight clearances and it looks like the doors are pushed out a bit where the cable passes through. Where did you all run your wiring?
Old Jul 17, 2010 | 10:54 PM
IgottaWoody's Avatar
I ran a mag mount ant on the rear roof area ( I bag the bottom to prevent scatches) run your coax down the side of the rear hatch and cross the hatch seal on the bottom... this way if you get into wet weather the wet will not seep all over the place..thru the center of the rear seats and on the centert consul..mine is a hand held so it fits between the seats...
Old Jul 18, 2010 | 11:15 AM
2003_2LT's Avatar
Does the loose cable rub anywhere? What about clips that would attach to the gate and hold the wire as it makes its way down?
Old Jul 21, 2010 | 08:20 PM
Didnt use clips...actually used a small bit of tape to keep it from moving....wire is hidden by rear hatch except where it pops out the top to the ant.....
Old Jul 22, 2010 | 09:46 AM
2003_2LT's Avatar
Hmm...my cable is too thick to exit through the top of the gate. I'll work something out.
Old Jul 24, 2010 | 08:25 PM
Too thick how? there will be some minor crush but this just helps hold it Doesn't have any ill effects.....you using some kind of monster coax?
jerij
"How To" Tutorial Library
40
May 18, 2019 07:44 PM
F-16C
Mods - Exterior
12
Feb 23, 2013 04:17 PM
mudbilly
Jan 7, 2012 10:09 PM
LowHHR
Feb 15, 2011 11:42 AM
