Replace factory radio HELP
Old May 6, 2011 | 10:12 AM
Robert617's Avatar
I have a 07 hhr and it does not have the sub, amp or on star and I was going to replace the factory radio with my aftermarket one But i herd if you use the regular wiring harness that you will loose the sound for your turn signals and the seat belts is this true? Also if I do use the regular harness is that all I will loose is the seat belt and turn signal noise?
Old May 6, 2011 | 02:31 PM
Lucky's Avatar
I beleave that is true. there are some other things you have to add with an aftermarket radio. use the search at the top of the page there is a lot of info on this.
Old May 6, 2011 | 11:57 PM
myrockabillykitty's Avatar
Yes you will lose all car sounds. My ls had an aftermarket stereo. It was weird at first but...i got used to it. Your dic should have a gate ajar msg so no worries there
Old May 7, 2011 | 12:50 AM
Give this thread a read, might have some info that you'll find helpful.
https://www.chevyhhr.net/forums/show...ermarket+audio
twr4d
Tires & Wheels
12
Mar 23, 2013 12:04 PM
07azhhr
Nov 10, 2011 02:55 PM
karen1953
Aug 17, 2007 09:02 AM
laylowcustoms
May 8, 2006 08:34 AM
