New Rear Springs, which end is up?
Old Nov 24, 2011 | 02:38 PM
I just got done replacing the rear springs on my 2008 LT with "variable rate" springs, since I regularly haul freight.
The question is: which end is up? The OE springs did not have any difference on the ends, the "variable" ones have a definite difference ; the last turn on one end is closer together than the other
(OE) I I I I I v. (new) I I I II.
I installed the "smaller" end up, I hope that's right.
Anybody got ideas?
Old Nov 24, 2011 | 07:28 PM
Variable rate or progressive rate springs are installed with the tightly wound coils facing down, if by "smaller" you mean the tightly wound end, then you got 'em in right.
Old Nov 24, 2011 | 08:07 PM
No, I got em wrong! But I will have to do it all over again when the shocks finally arrive. Thanks!
retrolled
Sep 12, 2013 11:40 PM
B@work
29
Aug 14, 2011 11:20 PM
