What is recommended brake pad material
Old Jan 12, 2012 | 08:39 AM
jdjaa1959's Avatar
What is the factory recommended brake pad material for my 2007
HHR???? From what ive seen OEM is non ceramic
also i have that unerving steering wheel vibration when stopping quickly
the rotors are still the originals at 56500 miles so ill install new napa ultra's
thanks
Old Jan 12, 2012 | 08:41 AM
solman98's Avatar
I believe the OEM is ceramics. That's what I replaced mine with anyway. Rotors might just need a cleaning up.
Old Jan 12, 2012 | 08:49 AM
db/sb's Avatar
Originally Posted by jdjaa1959
......the rotors are still the originals at 56500 miles......
To quote the Mythbusters, "there's your problem right there!" Had the OEM rotors replaced once under warranty and the problem returned shortly after. Replaced them myself with aftermarket rotors (Raybestos) and 30+k miles later the vibration has not returned.
Old Jan 12, 2012 | 11:10 AM
djr1973's Avatar
I put ceramics on my SS, stops alot better than the stockers, and dont have to worry about nasty black brake dust coated wheels anymore either,lol.
Old Jan 12, 2012 | 11:47 AM
solman98's Avatar
You have Brembo's correct? If yes, those are not ceramics stock.
Old Jan 12, 2012 | 12:14 PM
pitbull76's Avatar
Even the stock SS brakes are not ceramic. I also replaced mine with ceramic though as I wanted longer life and less brake dust(I understand I may have lost a slight amount of braking performance by doing so).
Old Jan 12, 2012 | 12:36 PM
solman98's Avatar
I always though the non Brembo brakes were the same as the non SS HHR's. Learn something new today.
Old Jan 12, 2012 | 02:07 PM
pitbull76's Avatar
The non brembo brakes can use the same aftermarket pads as a non-SS, but the material on the OEM pads is different. It grips well but puts off lots of dust and wears very quickly.
Old Jan 12, 2012 | 04:22 PM
hyperv6's Avatar
Solman has the right call with ceramic pads as the best to use in this application.
Just be sure to use a good quality pad as just because it says it is ceramic does not mean they are all the same quality.
EBC and Hawk are the best on the market and give the best performance and life. Many cheaper pads use cheap fillers and it does effect quality. They can call them ceramic but the quality can vary.
Old Jan 12, 2012 | 05:45 PM
panelmoxie's Avatar
i had same problem replaced both pads to ceramic and rotors. problem gone
