wheel bearing/hub assembly spacer
Old Apr 14, 2012 | 02:12 PM
dudley's Avatar
first time posting and was wondering What is the purpose of the Hub assembly spacer?
Old Apr 14, 2012 | 04:05 PM
to the forum dudley!
The wheel bearing hub spacer(or as GM refers to it...SHIELD. Brake Flange Plate), is there to provide the proper clearance between the flange on the hub, and the steering knuckle. If you're replacing your front hubs, its important to replace the spacer in the same orientation as it was removed.
Also its important to tighten the knuckle to hub bolts to 115 N·m (85 lb ft), and axle shaft nut to 110 N·m (81 lb ft).
Old Apr 14, 2012 | 05:50 PM
It also supposedly deflects water, especially on the TSB affected models. That is the reason for the "comb over" I think.
What does Chief Inspector Clouseau think "gardiner" means? Isn't it spelled different in French? "Jardinier" or somethin'?
Old Apr 14, 2012 | 11:06 PM
You'd have to ask Blake Edwards(dead since 2010)about the "gardiner" deal Don, you know how Clouseau mispronounced things like "minkee" for monkey.
jeffros hhr
Oct 10, 2019 08:35 PM
jbiesent
44
May 9, 2016 12:11 PM
jezmo
7
Jul 3, 2014 11:52 PM
babeba67
Maintenance and Upkeep
Feb 1, 2014 09:21 PM
mcgrosjr
Drivetrain (Excluding Engine)
Apr 24, 2013 11:44 AM
