pedders spring rattle
Old Apr 30, 2012 | 01:05 PM
badflt's Avatar
just installed pedders springs , now have a rattle on passenger side rear . anyone know what it could be
Old Apr 30, 2012 | 02:16 PM
Snoopy's Avatar
Just guessing.........maybe not sitting in the "channel" correctly. Maybe inverted the spring.
Old Apr 30, 2012 | 02:20 PM
Welcome to the site badflt, up side down ?
Old Apr 30, 2012 | 03:18 PM
to the forum badflt!
To echo those who preceded me, have you checked to see if its inverted, or did one of the spring insulators get left out?
Old Apr 30, 2012 | 03:23 PM
Snoopy's Avatar
Oops forgot about those. Bet thats it. They, after much use or severe weather, will stick to the old spring. Oh, and they really crush down to almost nothing but are probably essential to eliminate metal to metal rattle.
If you no longer have them, you can either buy new ones or, as an old thread suggests, make your own. Thin foam or rubber will do it.
Old Apr 30, 2012 | 10:12 PM
Putter's Avatar
I just ordered all new insulators from Rock Auto today for my upcoming spring install.
Old Apr 30, 2012 | 11:03 PM
Just in case you need the part numbers badflt, the upper spring bumper/cushion is GM PN#25993737, the lower spring seat/cushion is GM PN#10362783.
You can get them at Rock Auto, or your dealer, etc.
Old May 1, 2012 | 06:19 AM
badflt's Avatar
installed the springs the correct way and still had the noise , installed some rubber hose on the springs and all the noise went away and rides perfect
Old May 2, 2012 | 06:03 PM
moonsign's Avatar
I posted earlier about the Pedders springs. I found mine to be coil binding pretty bad. New upper mounts, with top spring end aligned with upper spring seat tab, seems to cure it. Found neither side were aligned correctly, at spring install, the first time. "Moon"
Vcode455
Jun 25, 2012 10:41 PM
bunkie
66
Apr 19, 2010 07:15 PM
Tikker
Apr 12, 2009 11:10 AM
