Lowest i can safely go without bottoming out, ever?
Old May 13, 2012 | 12:37 AM
hhrumadbruh's Avatar
I want to know the lowest i can drop the hhr without the tires rubbing on anything if i am on the freeway and there is a bump or something
Old May 13, 2012 | 09:55 PM
That's a tough question to answer..
While here & there may be 2 different answers.. Plus if you haul people & or stuff etc.. & GMC did not produce the hhr.
Need more specifics.. Also the model type of the hhr would help...
Old May 14, 2012 | 01:19 AM
And how big the bump is..
It's best to stick with a set of springs that others here have documented as working well for them. Any suspension will bottom out under the right (or is it wrong?) circumstances. Much depends on how "streetable" you want to go.
Old May 14, 2012 | 04:39 PM
badassbowtie's Avatar
i have scraped the front bumper on the ground leaving somewhat steep driveways with the stock suspension, so lowering it will only make it worse....so how low? i probably wont change anything on mine.
Old May 14, 2012 | 05:07 PM
swerv0428's Avatar
Personal opinion here. I drive mine daily and to lower the entire car would not be practical. If I pull up to far the bumper will hit most curbs and stoppers and like what was just said it will hit in steep driveways as well. So im lowering the back with cobalt ss springs. But everyone has there own opinion. I know many people who have lowered their hhr's.
Old May 15, 2012 | 10:42 AM
chefhhr's Avatar
I bottomed out on my first speedbump this morning. I'd say that if you have concerns about bottoming out, do as Swerv has mentioned and just drop the rear to even out the stance. I've got mine dropped about 2" in the front and 3" in the rear using a Canuck Motorsports Cobalt SS drop kit and it's pretty low...I have to go super slow over speed bumps and into driveways otherwise I'm bottoming out.
Old May 15, 2012 | 04:22 PM
swerv0428's Avatar
I will say that I love the stance of an all lowered hhr. But like chefhhr said if you dont mind going slow over bumps, etc. then id say do it.
Hey chefhhr. How are those grandsport stripes? Are those the ones off Ebay?
Old May 15, 2012 | 04:48 PM
Tyler Harvey's Avatar
Pedders make a spring that lowers you in the front 1 inch and 1-1/2 in the rear, if you have an SS.
Old May 15, 2012 | 05:26 PM
chefhhr's Avatar
Hand made them using plasti dip. I taped it off and painted with the plasti dip. Super easy to do. Im thinking about loosing them altogether. If I decide to keep them, I'm going to have them redone at a vinyl shop.
Old May 15, 2012 | 05:49 PM
swerv0428's Avatar
Im on the fence with them. I may do some in white.
