lowering springs
Old Jun 6, 2012 | 10:38 AM
capp002's Avatar
lowering springs
I need everyones opinion on lowering springs WHO HAS THE BEST LOWERING SPRINGS N THE LOWEST SETTING SPRINGS THANKS I have to buy new springs.
Old Jun 6, 2012 | 10:47 AM
chefhhr's Avatar
I like my canucks...I opted for the Cobalt SS version of the spings and so far have had good luck with them. I'm running the 17's with the factory tire which is a 215/50/17 I believe and I've got about a finger clearance in the front...finger and a half in the rear (inch in the front...inch and half or so in the rear). I'm wanting to go lower but honestly for most, this is probably plenty low enough.
Old Jun 6, 2012 | 11:37 AM
capp002's Avatar
Have you had any issues with the springs?
Old Jun 6, 2012 | 11:49 AM
chefhhr's Avatar
Only had them for about a month...but no, no issues.
Old Jun 6, 2012 | 12:05 PM
LawDog88's Avatar
Can I get a link for those springs?
Old Jun 6, 2012 | 12:14 PM
Here's the link....
http://www.canuckmotorsports.com/
Old Jun 6, 2012 | 12:46 PM
chefhhr's Avatar
Here's a couple of shots of mine right after install...they've settled a little since:
Here's a little more recent pic that I took on Saturday:
Old Jun 6, 2012 | 01:24 PM
capp002's Avatar
chef have you had any noise out of the front end when turning the wheel left or right
Old Jun 6, 2012 | 01:27 PM
chefhhr's Avatar
I've actually had a small amount of noise if I'm turning and hit a bump or dip at the same time. I didn't trim any of the bump stop so I'm not sure if that's where the noise is coming from...keep in mind I kept all my stock suspension setup.
Old Jun 6, 2012 | 03:51 PM
Turbo Hearse's Avatar
I've got a set of Canuck's for sale. Brand new. Never installed. Check the classified section
