Out of round brake drum
Old Jun 10, 2012 | 01:16 PM
Here's one I should know the answer to, but it's been too long.
I replaced my rear drums a short time ago, now one of them seems to be out of round/warped. Symptom being the wheel definitely scrapes and slows down in the same place when spinning by hand, and vibration from the rear while braking. Does not seem to be the bearing as it's at the same point and I cannot feel any play, it's a new bearing but it took 2 returns to get a good 1 out of the box.
When I did the last brake job I replaced everything from the backing plate out.
Question is: will having the drums turned fix out of round?
Old Jun 10, 2012 | 01:32 PM
If you are sure it is the drum, then yes turning it will true it up.
Have the brake shop check it first before making the initial cut with the lathe. They can tell you if it's "lopsided" or not.
Also, long shot here but check the hub contact area on the drum. Look for any possible stress cracks in the metal.
If it isn't the drum, then it's time to doublecheck the installation of those new brake parts.
Old Jun 10, 2012 | 01:39 PM
I have quadruple checked the installation. Today was the first time I thought to spin the wheel more than just an adjusting push. The entire mechanical system has been r&r d repeatedly due to stupidity and bad memory.
Chevy_dork04
Mods - Exterior
Aug 23, 2017 04:42 PM
toolman101
Nov 15, 2014 06:44 PM
Kookie
15
Mar 25, 2012 10:51 PM
fastsuv
Jan 12, 2012 04:19 PM
