Help!!!!!!!!!!!!!!!
Old Aug 26, 2006 | 06:44 PM
mudbilly's Avatar
Help!!!!!!!!!!!!!!!
I just got done intalling my amp (which sounds great btw, and I don'teven have the sub in yet)
BUT NOW
my car won't start, I did remove the + and - battery cables to install the amp....everything else seems to work except it won't crank....the little engine icon is also on.........
need serious help here
Old Aug 26, 2006 | 07:17 PM
ng8650's Avatar
Someone else had this problem, for some reason this only happens to a few, but after an hour or so the HHR will start up. Someone said that the cpu has to reset Give it a go after an hour or two.
Ng
Old Aug 26, 2006 | 07:26 PM
mudbilly's Avatar
will do..............but this will be a very tense 2 hours, i guess i have nothing better to do than drink a beer or three ....
Old Aug 26, 2006 | 07:52 PM
cyberone3's Avatar
if you have two key try the other one its the any theft making it not start it happened to me with the key i always use then i tried the other key that comes in the plastic bag then it started up and after that my regular key worked
Old Aug 26, 2006 | 08:02 PM
nfboy's Avatar
Yes try this. I had this problem as per my PM earlier...here is the thread I started.
https://www.chevyhhr.net/forums/problems-service-repairs-42/delayed-start-after-having-battery-unhooked-3806/
Old Aug 26, 2006 | 08:20 PM
mudbilly's Avatar
Thumbs up
y'all are my hero's :twothumbs
i just tried the other key and she fired right up
i figgered for sure that i toasted something
Old Aug 26, 2006 | 08:22 PM
JESSE's Avatar
Thats kool. Need some pics of the system now.
Old Aug 28, 2006 | 02:04 PM
mudbilly's Avatar
I talked to the dealer service department today. They don't have a clue as to why my original key doesn't work since I disconnected the battery. I can't remember if I had the key in the ignition or not when I disconnected it........ all my chimes don't work with the new HU...........but maybe some kinda power spike confused the key memory
I'm afraid to try it again, cause then maybe my second key won't work either..
They will re-program it when I go in for my first oil change
but it just doesn't make any sense to me, what am I supposed to do if the battery dies on a trip, I have to replace it, and I don't have the spare key with me .............
Old Aug 28, 2006 | 02:11 PM
Pizzaman's Avatar
did you buy an aftermarket hu? if so all of the chimes and dongs are gone. they are in the factory hu. no more crappy fake turn signal clicks for you!!!
Old Aug 28, 2006 | 02:35 PM
mudbilly's Avatar
yepper, ALL gone.............wonder how long it will take for me to lock the keys in the car
