putting in stock amp/sub?
Old Jul 27, 2012 | 08:28 AM
clwest25's Avatar
are they worth having, or just going with aftermarket sub/amp? I dont need anything fancy, as I just want a bit of extra bass. Parts at gmpartsdirect are about $120 a piece.
Old Jul 27, 2012 | 08:31 AM
oneton's Avatar
Your car is not wired for putting in stock amp/sub?
Go with aftermarket alot less work
Old Jul 27, 2012 | 09:48 AM
prod's Avatar
if you want to save space and dont mind taking apart the interior, you can use the factory enclosure and a small shallow sub, but the factory amp isnt worth the trouble, get an aftermarket one.
Old Jul 27, 2012 | 07:49 PM
clwest25's Avatar
I definitely want to use the factory enclosure. Otherwise I would put a sub in the extra storage space. I use my HHR mainly for work purposes, so I have a lot of parts in my cargo space and would not be able to put a sub in the main cargo space.
Old Aug 2, 2012 | 10:09 PM
clwest25's Avatar
Ive been looking around and found this sub with enclosure that I like. Fairly well priced too.
http://www.amazon.com/Power-Acoustik-THIN-10BX-10-Inch-Wooferbox/dp/B004U29BZO/ref=sr_1_4?ie=UTF8&qid=1343963259&sr=8-4&keywords=power+acoustik+enclosure http://www.amazon.com/Power-Acoustik-THIN-10BX-10-Inch-Wooferbox/dp/B004U29BZO/ref=sr_1_4?ie=UTF8&qid=1343963259&sr=8-4&keywords=power+acoustik+enclosure
Should I also look into one of the amps from Power Acoustik as well?
Old Aug 13, 2012 | 07:55 PM
hhrumadbruh's Avatar
You can make an amp rack and box under the cargo hold lid thing
if you don't really use the storage than that's a good route
taking the spare tire out will give you really good results if you want a big sub in there
ChevyGuySS
Oct 29, 2011 02:57 PM
orlandomon
Tires & Wheels
Sep 7, 2009 08:58 AM
K5ING
Apr 13, 2008 09:43 PM
08BlkSS
Apr 7, 2008 10:41 PM
Money in the Bank
Mar 24, 2007 02:57 PM
