cobalt amp/sub
Old Feb 6, 2013 | 07:30 PM
skyline26's Avatar
cobalt amp/sub
could this work in an HHR? is the "shape" of the box similar or can it be worked to fit in there?
anyone do this to their HHR?
Old Feb 6, 2013 | 07:50 PM
badassbowtie's Avatar
I suppose it would work but it is shaped differently....at least it is in my buddies 06 ss/sc. it actually has a small enclosured compare to being built in like ours. if I remember correctly
Old Feb 6, 2013 | 07:52 PM
To be exact...
Old Feb 6, 2013 | 08:10 PM
skyline26's Avatar
isnt the HHR's enclosed like that one? but behind the plastic siding?
Old Feb 6, 2013 | 08:36 PM
It could be....I just knew it looked a bit different. I would assume with it being a factory option, that it can't be all that different if its the same pioneers parts...
I have never taken it apart, I started to once, but you have to remove a lot of plastic to get at it.
I found this:
its out of an HHR on the forum somewhere. they do look similar in shape. The Cobalt pioneer enclosure looked to big from what I remember, to fit in the wall where the HHRs' is.
Old Feb 6, 2013 | 09:04 PM
07azhhr's Avatar
The cobalt one is a 10" I believe but the shape does look close. You could try it but you could also fit a better 8 or adapt the factory box to a 10. That is if you have one in your car already. Also I believe their amp is more powerfull then ours. But that is just from what i noticed on the net while looking for more info on ours.
camaro98z28
War Stories
Sep 9, 2011 09:31 PM
huckernage
Racing Discussion
Sep 15, 2010 09:33 AM
Jaxon
Racing Discussion
13
Sep 15, 2010 07:34 AM
chooch
Mar 10, 2008 07:49 AM
amberelyse
Jul 22, 2006 05:57 PM
