Bluetooth car kit mute factory radio?
I want to install a Bluetooth hands free car kit in my 2006 1LT HHR.
A function of the car kit allows it to MUTE the car radio. It basically
provides GROUND to one of it's wires when you answer or make a call.
Does anyone know if the standard CD/MP3/AUX radio has a "mute wire"?
If all else fails, I plan on connecting the car kit's mute wire to a
12 volt relay that will simply turn the radio OFF and ON, as if I had
turned the car key off. But I was hoping I could just MUTE the radio,
as if the MUTE button was pressed on my newly added steering
wheel buttons!
Any assistance would be appreciated...
Thank you.
wheel buttons!
Thank you.
wheel buttons!
Thank you.
wheel buttons!
Thank you.
nfboy, Thanks for reply.
I can press the MUTE button on the steering wheel control as you noted,
but I was wanting the Bluetooth Car Kit to automatically mute the radio
when I answer or place a call when I press the Bluetooth Car Kit button.
Any thoughts on how to "wire the car kit to the radio" to auto-mute the
radio?
Thanks.
radio?
Thanks.
radio?
Thanks.
Oh and i forgot to say welcome...wow I beat Deb to it.
We have bluetooth kits for sale at $315. Suppose to work for all vechiles, factory and aftermarket headunits, and go through the speakers, haven't tested one out yet though. My cell phone isn't bluetooth
. Let me know.
. Let me know.
I didnt bother installing my bluetooth kit when I had my stock radio on. I would assume you can connect to the existing mute cable leading to the steering wheel. I did however installed my bluetooth kit after I installed my Pioneer HU (it had a mute cable option) and it works great.
HHR PNOY,
I don't think the cable going to the steering wheel buttons would work like a normal "mute wire connection". I need a wire from the radio, that if grounded, would mute the radio and display MUTE to the driver... Is there such a thing? Thanks.
I work in the mobile phone industry. There should be something connecting to your radio from the Bluetooth car kit. When you receive a phone call and answer it the B/T signal will have the kit cut out the radio. Check to see if the manufacturer has a manual online. Motorola has a manual for every product online. I don’t install car stereo components so I hope I was useful.
Im sure the mute button is either negative or positive switched. You could do a relay to switch it to what you need. I believe your looking for something like this. But ofcourse it does not work for HHRs.
Louie McFarland to ChevyHHR.net where you'll find everything
