Aftermarket deck install
Old Aug 10, 2013 | 01:21 PM
onlyjds's Avatar
Hello,
I am wondering what is all needed to install a sony cdx-gt660up into my 2009 HHR LT, 7 speaker.
I am a bit confused by all these other things needed besides just a harness.
What I think I need:
Wiring harness
Dash kit
Antenna adapter?
Something for chimes?
Something for the steering wheel controls?
Thanks,
Onlyjds
Old Aug 10, 2013 | 02:36 PM
MsBecky's Avatar
Originally Posted by onlyjds
Hello,
Wiring harness
Dash kit
Antenna adapter?
Thanks,
Onlyjds
What you listed would be correct , all of the above .
Is it a pioneer factory set up ?
On Star ?
XM ?
http://www.metraonline.com/
Old Aug 10, 2013 | 04:51 PM
onlyjds's Avatar
I do not have onstar or xm. The only thing in the car, visibly without tearing things apart, is the grille over the subwoofer.
Old Aug 10, 2013 | 06:54 PM
jczboy's Avatar
Do you know if the deck will fit? Our cars have a very shollow area for the deck & only a few fit in the hole without cutting some stuff behind it.
You can get all the parts you need at crutchfield.com , to get everything to work it's pricey but worth it in the long run. Do your homework first then
Old Aug 10, 2013 | 07:41 PM
MsBecky's Avatar
Yep , it is shallow back behind the head unit .
Follow this link to this members install .... The steering first wheel adapter did not work . Use the Axxess ASWC , it will work fine ....
Shop around for you parts and head unit
http://www.sonicelectronix.com/
https://www.woofersetc.com/
Wire and fuses
http://www.darvex.com/store/pc/home.asp
https://www.chevyhhr.net/forums/audio-video-17/hhr-2lt-sounds-system-upgrade-pictures-45444/
Old Aug 10, 2013 | 09:43 PM
jczboy's Avatar
Axxess make a chime module too
Old Aug 11, 2013 | 12:13 PM
onlyjds's Avatar
So, I found a dash kit, wiring harness, and an Axxess ASWC-1.
Still need:
Chime box
Antenna adapter
Metra Online has AX-ADBOX1, is this my chime box?
They also show the following antenna adapters:
40-CR30
40-CR20
40-CR10
I think the first one is correct but I don't want to buy the wrong one.
Old Aug 11, 2013 | 12:44 PM
MsBecky's Avatar
Still need:
Chime box
Antenna adapter
40-CR30
40-CR20
40-CR10
Sonic electronix or crutchfield will sell you the correct parts you need .
I personally have my parts ordered by the installer . There is a host of reasons I do not touch the factory wiring in the dash . Mistakes can be costly...
The best advice I can pass onto you is go to your local installer and put it their hands .
If there is a problem , it is their problem and not your to fix .... These modules have been know to not work out of the box .......
Greg
cshaberts
Jun 15, 2017 08:35 AM
Chellesimm
Mar 29, 2014 06:12 PM
steveo3140
Jun 30, 2012 09:51 AM
Mondini
Feb 18, 2009 09:45 PM
kjlee2112
Nov 23, 2008 02:58 PM
