need to raise the back an inch
Old Oct 18, 2006 | 04:41 PM
I used Goldlines to lower my car. Loved the look!
Notice I said "loved". It had a nice level, lowered stance. But since I added the subbox and amps in the back, I've got a reverse rake going on!
I need to raise the back about an inch to level things out again.
Any suggestions?
Old Oct 18, 2006 | 04:48 PM
-md- HHR's Avatar
You could install shims, or if they were avalible install adjustable struts.
To make socal happy.
If there were adjustable STRUTS AND SHOCKS you could adjust how firm the SHOCKS were.
.....and also I see no reason why some type of shim could not be designed to work with either the rear SHOCKS or springs.
There is nothing MADE up in my post.
Old Oct 18, 2006 | 07:09 PM
O6ChevyHHR's Avatar
yea i would try the shims im sure your local auto parts store will have some! If not your local chevy Dealer would!
Old Oct 18, 2006 | 07:24 PM
SoCalHHR's Avatar
I can tell you guys with all the answers have had the springs out...
There are no shims that will work as the HHR springs have a special winding that hooks on a raised nib on both perches. If you had the springs out you would know this.
Adjutable Struts? Umm..the HHR only has struts in the front - not the rear.
Get real. If you have an answer that you know works - post it.
Making things up isn't helping anyone...
Old Oct 18, 2006 | 07:26 PM
courthousedeb's Avatar
Would something like the spring rubber they use in NASCAR work? I know it might sound silly, but it seems to work for them.
Old Oct 18, 2006 | 08:34 PM
mr.bungle's Avatar
you could maybe get springs with a stiffer spring rate or find coilovers that are adjustable. i've never used anything over than height adjustable coilovers, so thats all i know. can make the car go up and down with a few turns of the spanner wrench.
also... maybe air struts? or is it shocks in the rear? like a utility version you can raise and lower via a valve installed into the license plate bolt hole or something?
example:
Old Oct 18, 2006 | 09:32 PM
Black Beauty's Avatar
Too much weight
Any suggestions?
Try lightening up the load. First take the speakers out, then the spare ,see what you got.
Speakers are very heavy, may need to reduce your box size...
Old Oct 19, 2006 | 08:21 AM
JB1's Avatar
JB1
Any suggestions?
Replace your rear goldlines with these 1" drop springs
http://www.defrangeautocrafts.com/hhrlevelingkit.html
Old Oct 19, 2006 | 09:59 AM
Angelo already suggested that as a last resort, I'm hoping to find a solution that won't cost me $135.
Thanks though.
Old Oct 19, 2006 | 07:05 PM
O6ChevyHHR's Avatar
any idea how much the sub and amp stuff weigh?
