Antenna Connector
Old Oct 25, 2006 | 10:18 AM
Titans2's Avatar
Antenna Connector
OK - I have not changed a radio for a couple of years, and the last time I did I was confronted with GM's mini motorola plug... Now, I think I've got to deal with that again so I get the mini-motorola stuff... Nope.
I've never seen an antenna connection like the one that is on the HHR.
I'm trying to add a second radio to the same antenna, so I need to adapt from whatever to motorola, insert second cable, and back again to whatever.
Any suggestions?
Old Oct 25, 2006 | 10:55 AM
Lee3333's Avatar
The HHR actually uses a Chrysler antenna (like the PT Cruiser). The proper adapter is available at your local stereo store
Old Oct 25, 2006 | 04:04 PM
SoCalHHR's Avatar
If you have trouble tracking one down locally, we have them available in our store HERE.
Hope it helps,
Old Oct 25, 2006 | 05:54 PM
Black Beauty's Avatar
Be ever so careful. Another forum member had problems with the antenna, never did really find out the end result. The dealer tried several times to correct situation, maybe did.
Be Careful !!
Old Oct 25, 2006 | 06:56 PM
SoCalHHR's Avatar
Be Careful !!
Mike's problem was tied to the antenna base. He had fixed it once and the problem crept in again. We sell lots of antenna adapters to HHR owners and have only had one or two isolated problems ever reported.
Hope it helps,
mettec
Sep 21, 2015 03:47 PM
bigdehart64
Jul 6, 2014 10:26 PM
lasater
Jan 4, 2013 05:55 AM
Father Azmodius
Mar 15, 2011 12:43 PM
dpoll995
Jun 21, 2010 09:41 AM
