Start of System
Old Jan 23, 2007 | 10:50 AM
betterof2evils4's Avatar
Start of System
Well... I ordered the sub that I'm going to use in the system. It's a Power Acoustik Mofo 12" sub- 1200 W RMS.. I figured this would be enough wattage for that small space. The 270 watt premium system drops pretty good for what it is, so 1200 should do nicely.
Now, I'm looking for a mono channel amp that can run 1000-1200W rms at 2 ohms, maybe a 2-channel that can be bridged to do the same. I saw the Power Acoustik A1800DB, which is a mono, runs 1100W RMS at 2 ohms, good price as well.
Any ideas on for any other amps??
Old Jan 24, 2007 | 10:17 AM
Here's a link to the sub I will be using:
http://www.poweracoustik.com/pa2006/...O_wof_mofo.htm
and the amp I'm thinking about:
http://www.poweracoustik.com/pa2006/...O_amp_cabd.htm
Old Feb 18, 2007 | 09:31 PM
Well... got all my crap for the system....
And I'm getting it put in tomorrow. 1400W should be good in the car. Hopefully I can get some pics, show ya'll how it went...
Old Feb 19, 2007 | 12:11 PM
ng8650's Avatar
What kind of box are you using for the sub and where are you putting the amp?
Ng
Old Feb 22, 2007 | 12:27 PM
First, sorry it took so long to reply.
I didn't get it installed on Monday... it was President's day and the bank wasn't open, so I couldn't pay. But I had it rescheduled for tomorrow.
But with the system, I'm not doing any custom install like yours yet ...
I don't remember what kind of box it was, but it was $125 . It was the only thing they had close to what I needed. As for the amp, I guess I'll just stick it under the false floor. I just hope it gets enough air. I've seen a lot of people on here that did that, so it should be fine.
I'll let you know what kind of box it is and how it sounds tomorrow though
Old Feb 22, 2007 | 12:45 PM
HHR PNOY's Avatar
putting the amps in the middle compartment shouldnt be a problem. I had two amps there and it never overheated on me.
Old Feb 22, 2007 | 03:36 PM
ng8650's Avatar
Like PNOY said, heat shouldn't be a problem. I've got two amps sandwiched between MDF and plexiglass, no problems. Look forward to seeing your setup
Ng
Old Feb 25, 2007 | 03:06 PM
I had it installed, and it sounds awesome, but I cannot figure out how to post pictures. I can't copy and paste, and I don't know how to do the URL thing when it's from my computer and not the web.
HELP!!!!
Old Feb 25, 2007 | 06:55 PM
O6ChevyHHR's Avatar
pics?
Old Feb 25, 2007 | 10:17 PM
Yea... "pics" is an abbreviation for "pictures"...
