Lowering Question on 20's
Old Jan 24, 2007 | 06:46 AM
giant96's Avatar
Would the Eibach kit work with 225/35/20 tires? The Wheels are 5 x110, 7.5 wide, 42mm offset American racing Casino's. I want a 35 series tire for a little extra meat and I know the goldlines would def not work but would the Eibachs be ok??
Old Feb 7, 2007 | 01:55 PM
Ern's Avatar
Ern
bump becuase I wouldnt mind knowing.
Old Feb 7, 2007 | 02:22 PM
O6ChevyHHR's Avatar
i think you would be okay, thats almost the same setup I was going to go with.
Old Feb 7, 2007 | 07:52 PM
en0oNmAI's Avatar
You should definately be all right. Only rubbing you might experience is from really hard dips and bumps. You may to roll the rear fenders slightly to accomodate the larger tires. Its a very simple task that one can do in the driveway with nothing more than a WOODEN baseball bat!
Old Feb 9, 2007 | 07:37 PM
Ern's Avatar
Ern
What about a 235/35/20 on a 7.5 inch rim
Old Feb 9, 2007 | 08:44 PM
O6ChevyHHR's Avatar
7.5 you will be fine whats the offset?
Old Feb 10, 2007 | 11:32 AM
Ern's Avatar
Ern
42 offset but im just wondering for a 7.5 inch rim if thats a good size meaty tire.
Old Feb 10, 2007 | 11:43 AM
I didn't go to 20's, but I did go to 18's 7.5 and that's a pretty wide tire. I'm real happy.
Old Feb 10, 2007 | 12:53 PM
O6ChevyHHR's Avatar
If you want looks go for 20s if you want a good ride and looks go with 18s. ..
Old Feb 10, 2007 | 12:55 PM
How many cars have you owned, much less one with 18's or 20's?
