The XM Receiver is....
Old Jan 24, 2006 | 02:42 PM
jerij's Avatar
Located behind the plastic panel underneath the back passenger's side window. I discovered this while pulling the Onstar antenna off and following the leads. You can see it if you pull the trim panel back that's on the right side of the back door.
jerij
Old Jan 24, 2006 | 03:48 PM
wheelsee's Avatar
wait a second...it's in the door or the rear hatch area?
-wC
Old Jan 24, 2006 | 04:36 PM
jerij's Avatar
Ooops! Pull the right side panel off the back of the HATCH door area. There is a black ring holder with a black bolt that is also holding this panel on.
jerij
Old Jan 24, 2006 | 04:52 PM
wheelsee's Avatar
I'm guessing this panel right here held on by two bolts?
-wC
Old Feb 3, 2006 | 06:03 AM
monster5601's Avatar
-wC
Yep, maybe this picture will offer additional help.
Old Feb 3, 2006 | 09:21 PM
jerij's Avatar
Wow! Thanks Monster!
jerij
Old Feb 4, 2006 | 05:55 AM
1BadPig's Avatar
Anyone know where I can get extension cable to make use of the factory antenna with my Roady2?
Old Feb 4, 2006 | 09:48 AM
ivtech's Avatar
Try xmfanstore.com.
Charles
xtrememedic
Dec 27, 2008 04:14 PM
ccsubruce
May 22, 2008 12:48 PM
jerij
Sep 21, 2006 06:50 AM
kevhamner
Jul 11, 2006 12:05 AM
