Optima batteries
Old Jun 25, 2007 | 02:25 PM
Question Optima batteries
This was the response I got from Optima about their batteries.
Any thoughts?
Hello Mike,
Please accept our apologies for the delayed response.
Unfortunately we do not have a suggested battery for your vehicle due
to
your battery location. It requires venting to the outside of the
vehicle
and unfortunately we do not have the proper connections on our
batteries
for vent tubes or any venting accessories.
Please feel free to contact customer service at the number below if you
have any other questions. Thank you for your interest and support of
Optima
Batteries.
Bridget
Optima Batteries
Customer Service
Old Jun 25, 2007 | 02:55 PM
stuns's Avatar
I have a red top in Kelley's GTM since March. So far no problems. The ground cable was a little tricky to connect but it fit. I wonder how many car audio files have this as their extra battery in the trunk? Have they had any problems?
I let you see it on Saturday.
Old Jun 25, 2007 | 03:01 PM
Alzonie's Avatar
That's too bad! I was hoping to get one of those as a replacment when our original battery goes kaput! That should be any time now since we'll have had our HHR 2 Years in August, and batteries don't, as a rule, last much longer than that here in the Phoenix area. I'd rather not put another Delco Battery in it, given a choice. Just depends on where the HHR is when it dies. I told my Wife if it happens away from home just have AAA take it to the Dealer anyway. I wonder if an Exide, or a Bosch battery would be any better than the Delco?
Old Jun 25, 2007 | 04:47 PM
eat_world's Avatar
You could also use use a after market battery box into the trunk with a vent tube, making cables is to connect the old cables to the new box should not be too hard. Then all you would have to make would be mounts for the box.
Old Jun 25, 2007 | 08:29 PM
quest51210's Avatar
put it in the trunk, there will be no issues especially with a sealed battery like Optima's. you can also look into Kinetiks's...we have done both in multiples in SUV's,cars, and trucks.
Old Jun 25, 2007 | 08:32 PM
Why are they saying it needs to be vented?
Old Jun 25, 2007 | 08:40 PM
quest51210's Avatar
they are idiots. someone dropped the ball. we have done 16 yellow tops which were later replaced by 12 Kinetiks in a car trunk and all is still well.
Old Jun 25, 2007 | 08:43 PM
Snoopy's Avatar
I thought the battery compartment in the HHR is vented. At least there is a tube, from the battery area, through the bottom and exiting under the car.
Old Jun 26, 2007 | 06:40 AM
solman98's Avatar
I'm guessing they are saying that the battery itself is not vented for interior use. Placing in the trunk is a little different. I like Optima's, hopefuly by the time I need a battery, they have this addressed.
Old Jun 26, 2007 | 06:50 AM
Black Beauty's Avatar
My son has an Optima, yellow top, for his sound system.
It comes with mounting brackets, and apparently, it can even be mounted up side down. He hasn`t said anything neg. about it, and he`s REALLY picky about his RIDE. Not vented per-sa.
