Optima batteries
Ok, now you got me wondering. BB says they can be mounted upside down. Are they "glass mat" batteries? If that's the case, whoever said the Optima person is an idiot, is correct. Glass mat batteries do not need to be vented. At least the glass mat that I used in a sailboat didn't need venting. That's why I used it, for a confined space. I think I'll go to their website and do some research.
Red Top
Yellow Top
Currently no listing for the HHR (or Cobalt). Not sure if it is because of physical size or the venting.
The OPTIMA RedTop
The looks alone generate plenty of buzz. But it's the patented SPIRALCELL® Technology in OPTIMA RedTop batteries that's truly worthy of praise. OPTIMA RedTop batteries are built to withstand the abuse Trucks, SUV's and 4x4's experience on and off-road. SPIRALCELL Technology immobilizes the internal components of the battery, enabling OPTIMA batteries to withstand incredible amounts of vibration.
Vehicles modified for better engine performance demand more from a battery. OPTIMA batteries withstand the high underhood temperatures associated with these Performance vehicles. The sealed cells make the battery spill-proof, even if you install it on its side! This prevents external gassing and leaking which can damage engine components and limit battery performance.
If your battery is used in vehicles that demand extra reliability and performance, or if you just take pride in getting the best performance out of your vehicle, OPTIMA RedTop batteries deliver the performance you demand.
The OPTIMA YellowTop
Demand more from your vehicle? Then get more from your battery. OPTIMA YellowTop batteries are made for the extremes. If you have an extreme vehicle, you expect high performance. Whether your vehicle is made to take the abuse of off-road driving or cranking out decibels, you need more from your battery. OPTIMA batteries with patented SPIRALCELL® Technology deliver that performance. The deep cycle characteristic of this technology coupled with its extreme resistance to vibration provides performance vehicles with the repetitive power they need in a spill-proof package.
If your vehicle has a lot of accessories like running lights, high-performance stereo/AV system, winches, or hydraulics, your vehicle demands more from its battery. OPTIMA YellowTOP batteries provide the extra performance and deep cycling capability that your vehicle demands.
This response from Optima is really strange. If you're putting the Optima in the same location as the factory battery, I can't image why it can't be used
. The factory battery (which is a flooded-cell type) is much more vulnerable to spills and outgasses much more than an Optima. There's obviously protection built into the HHR to prevent outgassing from entering the passenger compartment. If it were my car, I would use the Optima without any worries, as long as it fit properly. Their response sounds like somebody there is confused about why they don't have a battery recommended for the HHR. The battery doesn't have the vent, the compartment does.
Steve
Steve
ive had a yellow optima that i got from Sams wholesale and paid $130 and it has been in since last June and not one problem.
the hhr has a battery vent on the back corner on the passenger side behind the bumper. 3 small square vent holes stacked on top of each other.
