South Pacific CA, NV, HI
Anyone in the SO CAL Los angeles/Montebello are? Help
Old Oct 11, 2011 | 11:27 PM
foxtrotraptor's Avatar
Hello I need some fellow HHR owners. I have a 2008 HHR SS. And I need some advice. I don't know the area too well. I'm looking for a good shop where the ppl know what they are doing. I'm looking to buy a new aeroforce guage, so I need a place where they can instal it. Also a place where which sells and can put on a working hood scoop. Any ideas? It would be greatly appriciated thank you.
Old Oct 13, 2011 | 07:17 PM
Uma's Avatar
Uma
Not my area of expertice. But, if you come out to Tom's farm om the 5th. You get all the info you need for sure. Hope to see you there. Todd (Uma)
Old Oct 14, 2011 | 06:20 PM
jay loukakis's Avatar
x2
Old Oct 19, 2011 | 11:36 AM
For sure. I already registered. Ill be there :)
Old Oct 19, 2011 | 09:16 PM
Uma's Avatar
Uma
Glad to hear that you will be there. Have you found any help with your questions yet? Todd (uma)
Old Oct 21, 2011 | 11:20 PM
Hey Todd yes and no.I got some good info on other stuff but I'm still looking for a place that would install a gauge. And also the hood scoop althou now I'm kinda reconsidering the hood scoop. Maybe at Toms Farm ill be pointed in the right direction.
Old Oct 22, 2011 | 02:14 AM
HipHotRod's Avatar
If you have the gauge, the install looks very straight forward. Quoting here "The install was a breeze. 1 bolt under the airbag sign. use a small screwdriver to remove that then undo the bolt 7mm. then pull on A-piilar in pulls right off. then unplug the 2 plugs 1's for the gauge the other is the Tweeter. undo the 2 nuts off the back of the gauge it slides right out of the hole. The gauge in return goes right into place. then run the 5' wire down and plug it in reverse the steps your finished" I believe it plugs in under the dash in the diagnostic port. Should be a piece of cake brother.
Old Oct 23, 2011 | 08:00 PM
Uma's Avatar
Uma
Better watch it Don, you may get a mod list going LOL, Todd(Uma)
Errricftw
Sep 13, 2014 11:20 PM
foxtrotraptor
South Pacific
Jan 24, 2012 07:45 PM
foxtrotraptor
Oct 10, 2011 05:50 AM
mizzouHHR
Mar 5, 2008 02:57 PM
BettieSpaghetti
South Pacific
62
Dec 30, 2006 11:39 PM
