1st Problem with the Stage 1
Old Feb 24, 2012 | 01:44 PM
  #181
09 Silver Bullett's Avatar
You need to take it to ZZP, they will fix it.
Old Jun 4, 2012 | 12:41 PM
  #182
bigjacksauto's Avatar
So was there ever a cure to this
Due to my Warranty I am looking into a GMTU
But YIKES after reading these posts it sounds scary.
I am hoping there is more people out there with Good Luck rather than bad luck with this
upgrade???????????????
Old Jun 4, 2012 | 02:32 PM
  #183
Turbo Hearse's Avatar
Soldered GMS1's had issues. The new pigtail ones do not. He also had issues due to a trifecta tune. He's no HP tuned and has no issues
Old Jun 4, 2012 | 05:18 PM
  #184
Thanks
Can I still expect to have the clearance issues with the new Pigtail turbo upgrade?
Old Jun 4, 2012 | 05:41 PM
  #185
foolmoon_design's Avatar
Yes, the tmap is the same.
  #186
Clearance is still an issue even with the new plug-in harness. Some have shimmed the IC forward(labor intensive). The upgraded stiffer motor mounts also help reduce the engine movement or rotation under torque.
I went the motor mount way. I also have a home made bracket between the oil pan and IC piping. When the engine torques and moves or rotates, the bracket slightly moves the IC pipe forward. This keeps the wiring and IC pipe at an equal distance,thus no rubbing.
Also zero issues with my upgrade going on 5 months.
Old Jun 4, 2012 | 06:06 PM
  #187
I am still saving up but i am trying to get all my notes together for the dealer.
It sounds like I will have to order the kit from crate engine depot
And then have the dealer install.
Is there anything else I need to warn the dealer about other Than the clearance issue.
I would hope that by now they would have that noted in the instructions but it does not sound that way.
Old Jun 4, 2012 | 06:24 PM
  #188
xonelife1983x's Avatar
i would say how long i have had my stage 1 and how many problems i have had but i dont wanna jinx myself
:WINK WINK:
but the service dude at dealer i went to actually did his "colbalt and a few others" so i hope he knew what he was doing
Old Jun 4, 2012 | 06:39 PM
  #189
Still would love to see a 1/4 mile et and mph
Before. And after the upgrade in an auto.
Going from 235 to 290 in first and second sounds like it should be a huge difference
Old Jun 4, 2012 | 08:14 PM
  #190
hyperv6's Avatar
The gains are limited by the FWD. The more power is more difficult to put down with the Pilot tires. It is so easy to unload the front tires it is crazy.
On the other hand the car feels so much better than the stock 235.
