1st Problem with the Stage 1
Old Nov 11, 2011 | 07:09 PM
  #71
ATLsilverSS's Avatar
Originally Posted by KissMy08SS
Everything has been soldiered and a bracket has been made so the lower sensor does not come in contact with the AC compressor. I tryed to move the wastegate rod....but I couldn't get it to move at all. The nuts are still in place. I checked the BPV as well, the diaphragm looks good...I'm going to go ahead and replace the spring with a dejon spring as well.
what about the nipple on the wastegate......
refer to post 13.......https://www.chevyhhr.net/forums/show...t=23231&page=2
Old Nov 11, 2011 | 07:44 PM
  #72
here is what i was referring to with the wastegate rod nuts.....post 152
https://www.chevyhhr.net/forums/show...=23231&page=16
Old Nov 11, 2011 | 08:39 PM
  #73
KissMy08SS's Avatar
Thanks for the pictures.
Just checked the nuts....and they are fine and intact....
Old Nov 12, 2011 | 08:05 PM
  #74
KissMy08SS's Avatar
Installed the replacement oring on the upper map sensor...did absolutely nothing....no change in how it runs...guess I can take that off of the list. What to do....what to do...
Old Nov 12, 2011 | 08:14 PM
  #75
XtremeSS's Avatar
Did u install your ic piping and intercooler yet?
Old Nov 12, 2011 | 09:02 PM
  #76
KissMy08SS's Avatar
The only thing I haven't installed or done yet is the upper IC pipe....ZZP said they are getting powder coated right now and should be sent out next week. I guess it's possible the upper IC has a hairline crack or something huh?....I highly doubt it though....
Old Nov 13, 2011 | 08:38 AM
  #77
its possible but it more than likely wouldn't behave like you have described.
inspect the wires that run from the map sensors to see if they are damaged in any way or coming in contact with anything. from every stg 1 issue i have ever read about it is almost always something to do with the lower map sensor or wiring.
Old Nov 13, 2011 | 10:40 AM
  #78
KissMy08SS's Avatar
I wish there were someway I could just get a whole new harness (not sure what it consists of) and get the plu-n-play adapter kit for the GMS1....that way....I could atleast rule out any type of wiring issue. (no connectors, soldiers)
Old Nov 13, 2011 | 10:44 AM
  #79
Nice thought you aren't the first to have it. The original got snipped.
Old Nov 13, 2011 | 01:53 PM
  #80
KissMy08SS's Avatar
You think I should go ahead and replace both of the TMAP sensors? (upper and lower)? That's the only thing with the GMS1 kit that hasn't been changed yet.....
