2010 SS lagging down at full throttle start
Old Dec 12, 2010 | 05:50 PM
Never had mine loose power under hard acceleration.Lately I have been driving in comp mode because I don't like the feedback when the computer "takes control"( esc,tc). If it spins in comp mode,it spins.No power reduction. Sounds like the OP's car is not recognizing the comp mode input. Have the dealer take a look. This is not normal.
By the way.Mine is also a 2010 without turbo upgrade.
Old Dec 12, 2010 | 06:38 PM
Spozo's Avatar
Can you try something for me? Put it in comp mode, put the transmission in "I", one foot on the brake, the other on the gas, bring the RPM's to 1500-2000, take your foot off the brake, plant the accelerator and tell me what happens. If yours doesn't spin then cut, and ignore the APP input until everything calms down, I'll bring mine in to the dealer this week.
Yes, I'm serious.
Thanks.
Old Dec 12, 2010 | 06:58 PM
Kev&Chers{SS}'s Avatar
I didnt get a chance to BUT, Would this have ANYTHING to do with freezig weather? Temp outside was 29 when this occured. Could the computer be sensing it could be ice and have only usable power to get car moving? Immediatly when I took off gas and replanted, it came back to life, or did 5mph roll and floored, it was also fine... Made me think...
Old Dec 12, 2010 | 07:00 PM
Also keep in mind, NO codes or warning lights, just the flash of TC working after breaking tires loose initally
Old Dec 13, 2010 | 07:28 AM
bartSS's Avatar
I dont have any issues with mine roasting tires. I can sit in one spot doing so and the car wont pull power one bit
Old Dec 13, 2010 | 07:29 AM
bartSS's Avatar
Was your car fully warmed up?
Old Dec 13, 2010 | 01:40 PM
Yes checked that too 190 on the coolant. Strange it runs fine all other times.
Old Dec 13, 2010 | 05:08 PM
IgottaWoody's Avatar
Plus your in COMP mode....which is used for performance runs...goes counter to the intended results....go to traction off and ECS off mode and see what happens...this turns everything off........hold the TC switch for 10 sec...report back
Old Dec 13, 2010 | 06:53 PM
Spozo's Avatar
Is yours a 2010?
Old Dec 13, 2010 | 06:54 PM
Spozo's Avatar
Mine will do the same, regardless of the ECS/TCS mode.
