299 codode underboost
Old Sep 8, 2018 | 12:37 AM
bdfab.com's Avatar
299 under boost hit 10 lbs. then falls on it's face
Old Sep 8, 2018 | 08:31 AM
And .........?
Old Sep 8, 2018 | 08:53 AM
bdfab.com's Avatar
299 code
10 lbs. Of boost is Max. Hits 10 then falls on it's face, no boost no acceleration. Getting worse and is shifting. I bought a actuator kit have not put it on yet.
Old Sep 8, 2018 | 09:14 AM
Cat Man HHR's Avatar
Did you check hose clamps that hook up to the turbo, intercooler and throttle body ?
And what do you mean "Getting worse and is shifting" ?
What actuator kit are you referring to ?
Old Sep 8, 2018 | 09:40 AM
You have to use your words, we can't guess what you are looking for.
I am assuming the code in question is P0299?
Old Sep 8, 2018 | 09:41 AM
Hmm. Not even sure what those 2 above mean, (in blue)
Maybe add a little detail to your post. Start with the year SS and transmission, then some better details to the problem.
Old Sep 8, 2018 | 01:28 PM
Possibly a trashed turbo, if it is P0299
https://www.obd-codes.com/P0299
Old Sep 9, 2018 | 07:34 AM
DrLoch's Avatar
Broken, how do I fix?
Old Sep 9, 2018 | 09:20 AM
Here is the basic fix>
Old Sep 9, 2018 | 10:24 AM
Let's see if the person chimes back in.
