Brake Bleeding Procedure
Old Dec 15, 2018 | 12:08 PM
m_ridzon's Avatar
I visited my library today to look up the Mitchell's Manual for the Brembo brake bleeding procedure. It says to bleed the brakes in this order:
  1. Right rear
  2. Left front (Brembo inboard bleeder followed by outboard)
  3. Left rear
  4. Right front (Brembo inboard bleeder followed by outboard)
This doesn't make sense to me.
All the brake bleeding I've done over the years, I've always done it "farthest from the master to the closest." That is...
  1. Right rear
  2. Left rear
  3. Right front
  4. Left front
Can anyone confirm what the proper sequence should be? Is the Mitchell's Manual wrong?
Thanks in advance!
M Ridzon
Old Dec 15, 2018 | 01:39 PM
It is because the MC is split different from the 20th century.
That procedure is farthest first.
Old Dec 15, 2018 | 01:54 PM
m_ridzon's Avatar
So you're saying to follow the Mitchell's sequence?
Old Dec 15, 2018 | 02:31 PM
Yes the Mitchell’s sequence is correct , use it.
Old Dec 15, 2018 | 02:39 PM
Even though we dinosaurs have been using the old version until somebody bothered to read the new docs and corrected us.
Old Dec 15, 2018 | 05:33 PM
Yes, I recall being corrected, and I thought I knew it all!
Always learning , happily not the hard way, in this case.
Old Dec 15, 2018 | 08:37 PM
Well thanks guys, I learned sumthin' new today.
Old Dec 15, 2018 | 10:05 PM
And to add. You really should use a brake pressure bleeder if your car has antilock brakes.
Old Dec 16, 2018 | 01:43 PM
m_ridzon's Avatar
So if I leave the rear calipers alone and do a front caliper swap from non-Brembo to Brembo, I have to bleed the rears in sequence with the fronts? That doesn't seem to make sense to me, but perhaps there's more than meets the eye. Perhaps the rears will be affected by the fronts being opened. Therefore, I'll just play it safe and do them in order.
Old Dec 16, 2018 | 02:07 PM
The MC is split diagonally NOT F/R like 20th century with no ABS and Traction Control and Electronic Stability Control.
So, yes opening the front left means bleeding the rear right.
