Engine cradle
Old Sep 1, 2022 | 12:25 PM
greg8453's Avatar
Originally Posted by donbrew
The nut didn't come from the factory welded it is captured in a cage.
Please stop disinformation.
Wrong vehicle
10-4
Old Sep 2, 2022 | 10:51 AM
FirstGenHHR06's Avatar
Is there some reason to completely avoid a GM parts department or ebay?
Right? So another question should I start with the front ones or does it matter?
Old Sep 2, 2022 | 11:17 AM
fastsuv's Avatar
I would get the correct GM part number bolt.
The GM part will have the correct length of the threaded part, along with the correct hardness and a flanged head.
If you look at the end of the GM bolt, its not flat - there is a slant across the width. This is to help align the various parts that the bolt goes through (control arm bushing, subframe, and cage nut) as you push the bolt up.
Steve
Old Sep 2, 2022 | 11:54 AM
Steve
Does it matter where I start the front,back,left side, or right side?
Old Sep 2, 2022 | 12:06 PM
I don't know how it would matter.
Old Sep 2, 2022 | 12:07 PM
No, doesn't matter. Get all 4 started, then tighten them to the torque spec. Not easy getting that torque + angle while laying under the vehicle.
Old Sep 2, 2022 | 12:28 PM
I Have it on a lift and it's just me I'm 110 pounds and need it idk
Old Sep 2, 2022 | 12:43 PM
https://www.chevyhhr.net/forums/how-...e-items-54648/
All 4 of the cradle bolts are 74 lb ft then 180 degrees.
Old Sep 2, 2022 | 12:57 PM
That 180 degrees, that's the hard part. The lift should make it easier
Old Sep 2, 2022 | 01:09 PM
Torque to 74 ft/lbs then two 90 degrees pulls to finish up.
advisual
Sep 20, 2022 12:09 PM
Canis_maj0ris
Sep 2, 2022 06:25 AM
FatTireBiker
Oct 14, 2014 10:31 PM
LTman
Maintenance and Upkeep
Mar 4, 2014 07:40 AM
hotrodredss
Mar 21, 2012 10:47 PM
