fe5 lower a arm, best price
Old Aug 26, 2013 | 07:20 PM
cannuck's Avatar
need to get a pair. who has the best prices. a little on the hard to find as everyone carries the regular stuff.
Old Aug 26, 2013 | 09:53 PM
prod's Avatar
Im pretty sure all HHRs have the same part number on the control arms, every source Ive seen anyways. Id recommend to get some with the bushings already installed.
A good upgrade from powellraceshop, they are a much better part.
Old Aug 27, 2013 | 11:17 AM
cannuck's Avatar
the ss is a special part different than LS
Old Aug 27, 2013 | 11:29 AM
IgottaWoody's Avatar
only difference is the ball joints..
Old Aug 27, 2013 | 12:13 PM
x2 - cause the SS has a different steering knuckle that uses the bigger lower ball joint.
Old Aug 27, 2013 | 01:36 PM
Look at the Ebay. I have had good results from Prime Choice and a couple of other vendors there.
If you just want bushing your local auto parts will probably be best on account of shipping etc.
Old Aug 28, 2013 | 12:01 PM
I swapped out the ball joints ( Moog ) and the bushing GM parts direct , on the original LCA's on my Lt a few months back, but I did see SS units on several sites
