Front Sway Bar Bushings?
Definitive? Scroll down in here to page #4 under suspension, then to sway bar bushings
FE5 that's gonna confirm y'all need the 23 mm 9-5159's which are greasable, I put in 90 degree zerks andponit them out towards the strut, makes greasing a much simpler job.
https://www.chevyhhr.net/forums/comm...-part-i-48833/
x2 what old blue said.
Energy suspension are great, but you do have to grease them regularly. I do mine with every oil change.
the OEM ones on the SS are also poly, so you could replace them with OEM. They have a pretty decent life.
Sneezy
55
09-17-2010 11:25 AM
