Front sway bar setup
Dropped by Maier Racing, to chat with Mike Maier[former SCCA autocross and Road Racing champion], and he gave he some tips[one of which I found intresting].
He had watched my two, last minute runs, at the Goodguys autocross, last fall, and said "Your SS opened up more than a few eyes, hazing the tires at WOT, and your times were faster than a lot of V8's". Unhook your front sway bar and trust me you will be quicker" He showed me on his heavily modified Mustang, that he does'nt even run a front bar.
So, come April when I run the autocross next, I will unhook the front bar.
Weather gets better, think I'll test it out. "moon'
The SS comes with a front sway bar, and no rear 'swar bar' from the factory. That's why most of us have installed a rear sway bar only. You can upgrade the front sway with an Eibach piece (that's the only one offered for us as far as I know) but you need to basically unkhook the front cradle to get it on or have a shop do it for you. From what I've read + seen the front sway doesn't really need to be upgraded unless you're getting into hardcore road racing.
Later
Allex
Later
Allex
Later
Allex
Later
Allex
Oh, the SS has a 23 MM front bar. The "plain" HHRs have a 25 MM front. Food for thought!
