Fuel Injector Pressure sensor location
Old Oct 11, 2021 | 04:29 PM
chevcat's Avatar
Hi,
I cannot find the location of the fuel injection pressure sensor (ac delco 2134420} I am getting a P0090 code and
the car has a new ZZp fuel pump and a new in tank fuel pump.
Thanks for any help.
Old Oct 11, 2021 | 04:56 PM
#2 on the diagram. GM p/n 12621292
Old Oct 11, 2021 | 05:05 PM
chevcat's Avatar
Thank you!!!
If I am reading the diagram right the sensor is near the coolant container side.
Old Oct 11, 2021 | 06:14 PM
Yes, that is correct.
Old Oct 11, 2021 | 07:05 PM
chevcat's Avatar
Ok , I was just at the car, it looks like it is possible to remove it by reaching
from below the car when it is on ramps. Has it been done this way?
Thanks
Old Oct 11, 2021 | 07:41 PM
The Haynes manual doesn't indicate that anything has to be removed to get to it.
I did mine with the engine out of the car, so I don't really know. I just looked, maybe just removing the radiator hose would give easy access. I think I wouldn't want to do it from below.
Old Oct 12, 2021 | 07:33 AM
That’s it on the left, at the end of the fuel rail you can see the harness connector
Old Oct 12, 2021 | 07:32 PM
chevcat's Avatar
Thanks for the picture and info, the sensor arrives tomorrow and I will
get to it this weekend,
Old May 13, 2023 | 07:02 PM
RA021926's Avatar
What is the part number for #10 on the first diagram?
Old May 13, 2023 | 07:20 PM
It’s for an LNF turbo charged 2.0 direct injection engine, not applicable to your 2006 engine
