Gasket coverage?
Old Mar 18, 2013 | 09:26 PM
AJL08SS's Avatar
Gasket coverage?
I have noticed that in the last few thousand miles my valve cover gasket has started to drip slowly (only enough to deposit a very thin film that attracted the grime to draw my attention).
I would assume they would be covered in the powertrain warranty, but I feel like dealerships would give me a hard time since it isn't leaking "enough" to actually run the oil supply down at all between changes.
It only leaks enough to make the block dirty between changes so I can conclude the inevitable issue is now in its infancy.
Old Mar 18, 2013 | 09:30 PM
Snoopy's Avatar
Why not ask the dealer first before you reject it yourself. Nothing lost, nothing gained.
Besides you are approaching the end of you power train warrnty....5 year/100,000 mile, which does cover it. Go for it.
Old Mar 19, 2013 | 01:05 PM
Good advice from Snoopy!!! But don't go into the dealer with it freshly cleaned - let it get a bit messy first so they can see that there is an issue with it.
pyro panel
Canadian Mid East
Dec 22, 2012 09:00 AM
emill713
Dec 19, 2011 08:45 AM
pyro panel
Nov 26, 2011 06:26 PM
stick
Apr 13, 2008 06:38 AM
Impala2HHR
Dec 9, 2007 10:19 AM
