K&n air intake and programming.
Hey everyone. Thank you for your help ahead of time
but. I just recently bought a 08 as 2.0l and the stock air box lid it broken and taped up and the intake tube has a air leak due to a crack in it. And I not near ready for tuning thier more I want to due when I go to get it tuned . But I am looking at 7-3069 K&N PERFORMANCE AIR INTAKE SYSTEM.and this reuses the stock bottom but replaces the lid, tube ,& filter for more flow. Has anyone installed this kit? And if so did u have to get the tune done? ... I know I may not see the power gains but at least I am hoping to be able to drive the car with out having to tune the car |
Welcome to the site, if you send hellshotrod a PM he might have the OEM parts you need, just click on his name and a window will drop down then click on send message. David is a great source of HHR parts
https://www.chevyhhr.net/forums/www....ad.php?t=63306 |
Originally Posted by Ss_jeff
(Post 896781)
but. I just recently bought a 08 as 2.0l and the stock air box lid it broken and taped up and the intake tube has a air leak due to a crack in it. And I not near ready for tuning thier more I want to due when I go to get it tuned . But I am looking at 7-3069 K&N PERFORMANCE AIR INTAKE SYSTEM.and this reuses the stock bottom but replaces the lib tube and filter for more flow. Has anyone installed this kit? And if so did u have to get the tune done? ... I know I may not see the power gains but at least I am hoping to be able to drive the car with out having to tune the carWhen you say "air tube" is it the hose going to the air box ? If it is and the top lid is broken the only thing that will happen is the engine will be getting hotter air going into it. The lid helps to keep the stock air filter in place also. You don't need a tune if you install the K&N filter. Pictures of the top lid and tube would help also. What is a lib hose ? Use your spell check. |
What I mean buy tube in the tube from air box to the fresh air inlet side of the turbo
Yes old blue that is the set-up I was referring to
I’d send hellshotrod a PM for the OEM lid and pipe
I really appreciate the help and info from every one. I will have to hit him up when I get back on my had some financial set backs. That's again.
He’s a fair guy, as he says in his ad in the classified ads, he might just charge you shipping!
(Post 896834)
