Knock sensors P0332
Old May 8, 2023 | 06:53 AM
  #41
What happened to your post?? I fixed the text color.
To test P0332: disconnect and put your VOM between each the contacts of the harness to ground. If you get 2-5 volts get a new KS.
The KS is basically an electret microphone.
Old May 8, 2023 | 08:15 AM
  #42
hhrumadbruh's Avatar
I need to get around to swapping mine. Any luck with non-oem?
Old May 8, 2023 | 09:40 AM
  #43
On the SS, both knock sensors are the same part number. So if you don't mind the labor, you could swap #1 with #2 and see if the DTC changes. But it does seem like a bit of work. When I was looking, the new didn't seem very expensive. Around $20 if I remember.
Old May 8, 2023 | 09:45 AM
  #44
Ive got 2 new ones from rock auto. Heard the car only likes OEM which are around $40 each from the dealership.
Old May 8, 2023 | 10:23 AM
  #45
Install the RA parts, and see if your SS likes them
Old May 8, 2023 | 11:04 AM
  #46
If you ask someone that works for GM do you expect them to say "use any brand"? Where is the profit in that? Especially for an item that costs 2 cents to make.
Old May 8, 2023 | 12:09 PM
  #47
I don’t work for anybody, most parts come from the same source just different packaging, some are bootleg crap some are just as good as OEM, some are better than OEM. Most OEM GM parts are becoming obsolete for these SS’s and some LS/LT parts also.
Old Jul 13, 2024 | 06:31 AM
  #48
PulpFriction's Avatar
TLDR - Does anyone know for sure what the correct GM p/n is for the #2 knock/detonation sensor for a 2010 HHR SS manual?
My P0322 is back, except this time, it won't go away. (To save readers from scurrying around previous posts, previously, it would just appear sporadically.) So I guess I have to address this. Quite drivable but somewhat less power and fuel economy as the ECM dials back the timing just to be safe.
I don't want to dig in without having the part on hand. Yeah, maybe just a chafed wire, but from what I've read, it seems there's a high probability it really is a bad part.
I'm having trouble ascertaining the right GM part number, and I'm finding inconsistencies in the part number crossovers. This is a critical performance part and the correct operating properties a crucial; even slightly wrong signals could result in suboptimal ignition timing, or worse, allow a damaging level of knocking.
I'm assuming #1 and #2 are the same.
As we well know, the parts peddlers' "fits" is not the same as correct.
I need to at least start with the correct GM part number. Does anyone have this from an authoritative source? I've been to Rock Auto and they list several, but no GM #. (They do list an NGK/NHK that I would trust in a pinch.) Otherwise, I'm calling my Chevy dealer parts dept. on Monday.
TIA
Old Jul 13, 2024 | 07:33 AM
  #49
The part number is 12621820. Fits many GM variants, I suggest the wiggle test the sensor may be loose, just snug up the bolt .
Old Jul 13, 2024 | 08:54 AM
  #50
That is the number the "book" says for the 2.0. The ACDelco number is 213-4583/GM 12621820.
My guess is NGK/NTK makes the part.
I would also look at loose pins in the ECM connectors.
