"Limp Mode" issues P101 and P106 codes
Well
I figured I better create a new title for the issues I have had with My HHR SS in the past month or so. I started another thread a while back https://www.chevyhhr.net/forums/2-0l-performance-tech-46/hhr-ss-shutting-off-running-rough-about-first-few-minutes-each-morning-s-46920/ and everyone has been great about adding info But this title better suits what I am now experiencing and also from the research I have done it sounds like alot of HHR SS Cobalt SS Solstice GXP and Saturn Sky owners have either experienced or are still experiencing from time to time. Usually ends of being a boost leak and or wiring from what I am told but a lot of times it seems there is never a true reason found.I am not sure but this does not seem to be the case with trifecta tuned or hp tuned vehicles but I could be wrong. You are Driving along for months if not years and then all of a sudden you car goes into the dreaded LIMP MODE:skull1: which consists of loss of power car sometimes starts running rough to the point you have to pull over and turn the car off and back on. In my case yes the wiring had been hit on the lower sensor so new wiring tons of room new MAF sensor New Tmap Sensors New Spark Plugs New Upper charge pipe that was leaking New O2 Sensor Upstream Car will normally run a couple or few days and out of no where it goes into Limp Mode Hopefully this will help future owners to find a 100 percent resolution it seems that a good majority of Solstice owners have this issue as well even with the stock sensors. |
Originally Posted by bigjacksauto
(Post 716062)
Well
I figured I better create a new title for the issues I have had with My HHR SS in the past month or so. I started another thread a while back https://www.chevyhhr.net/forums/showthread.php?t=46920 and everyone has been great about adding info But this title better suits what I am now experiencing and also from the research I have done it sounds like alot of HHR SS Cobalt SS Solstice GXP and Saturn Sky owners have either experienced or are still experiencing from time to time. Usually ends of being a boost leak and or wiring from what I am told but a lot of times it seems there is never a true reason found.I am not sure but this does not seem to be the case with trifecta tuned or hp tuned vehicles but I could be wrong. You are Driving along for months if not years and then all of a sudden you car goes into the dreaded LIMP MODE:skull1: which consists of loss of power car sometimes starts running rough to the point you have to pull over and turn the car off and back on. In my case yes the wiring had been hit on the lower sensor so new wiring tons of room new MAF sensor New Tmap Sensors New Spark Plugs New Upper charge pipe that was leaking New O2 Sensor Upstream Car will normally run a couple or few days and out of no where it goes into Limp Mode Hopefully this will help future owners to find a 100 percent resolution it seems that a good majority of Solstice owners have this issue as well even with the stock sensors. |
Stock ac delco filter from the dealer with about a couple thousand miles on it
The fact that you are still getting the TMAP code makes me think you still have a bad/intermittent connection or ECM bad or needs reprogramming
Or all three, before the dealer just gives up. I hate to say this, but that never stopped me before..:lol: A very nice fella that was a member here, Gasman had some similar issues, Chevrolet finally gave up trying to make it right and bought it back. Sunflowerhippie same deal. Have you got any assistance from our resident Chevrolet service advisory yet ?
thanks for the advice
I dont think the dealer has given up yet as of yesterday they where going to check with Gm All the research I have seen shows that a lot of soltices have this issue I am guessing at this point that its oil on the tmap sensor that causes it. I have been told that a lot of these cars will actually acumulate oil in the intercooler. and then at times they will pull or have the oil pushed up into the intake. |
3 Attachment(s)
Here is a shot of when it is running rough going into limp mode
[attach][attach]Attachment 15102[/attach][/attach] the other 2 pics above are of the upper tmap sensor after it goes into its limp mode. As others have suggested possible pcv issue still looking for a pcv hose routing diagram with the add on electric vacuum pump for the brakes |
1 Attachment(s)
Here is a picture of the electrical tape that I found when I pulled the plastic covering back of the wires that go to the ecm
anyone know what these color wires (blue and gray) do. I thought maybe they where in here when they added on the vacuum pump for the brakes but according to the instructions this is not the side they deal with. Attachment 15103 |
So did they check for coking on the valves yet?
Not yet but from the pictures I have seen most all of the di motors have that issue.
I will run it by them. |
