Motor knocking
Old Aug 9, 2023 | 08:37 AM
AbeL_Legend's Avatar
Motor knocking
Hello, yet another problem with my '08 SS has come up. Whenever I start my car, it starts to make a knocking sound. However, whenever I turn the car off and back on, it either decreases in volume or goes away altogether. I have no idea what this could be, and I'm not getting any codes to help narrow it down.
I took a video, but the file was too large for the site, so I uploaded it to youtube. Here's the link;
What could this be, and is my car okay to drive? Thanks
Old Aug 9, 2023 | 09:46 AM
I would suggest that you don't drive it until you pop the cam cover off and look at the timing chain; any slack between the sprockets is bad.
Old Aug 9, 2023 | 01:20 PM
If it had something to do with the timing chain, wouldn't it continue to do that even after turning the car off and back on?
Old Aug 9, 2023 | 01:43 PM
No. The main symptom of a bad timing chain is "rattles on start goes away on warm up".
Old Aug 9, 2023 | 02:21 PM
After you turn the ignition off then restart the engine you can still hear the noise faintly, could be timing chain slack, could be HPFP noise have a listen up on the driver’s side of the cylinder head.
Old Aug 9, 2023 | 03:11 PM
Forgot about the High Pressure Fuel Pump. It is cam driven and makes noise when failing.
Old Aug 9, 2023 | 06:17 PM
I thought the timing chain (and HPFP) were more like chatter than this knocking sound on the video.
Old Aug 9, 2023 | 06:52 PM
Need a video from under the hood. Move the camera around so we can try to pinpoint where the noise is coming from.
Old Aug 9, 2023 | 08:11 PM
Will do. I listened to it under the hood and I can't really tell where it's coming from, but I'll take a video in the morning anyway.
Old Aug 9, 2023 | 08:53 PM
You should be able to feel that with a finger.
