New SS TSB
Old Jul 11, 2008 | 03:47 PM
ChevyMgr's Avatar
Originally Posted by 405HP_Z06
What years? I've never had this DTC in my Z06.
2005 is when I first saw one so that year and newer. I also set one myself in a stock unit SS HHR that I drove right after transport delivery.
Old Jul 11, 2008 | 04:10 PM
Grimster's Avatar
How can I find out what ECU program version I have? The dealer insists it has the latest and was done on 06-01 when I took it in the FIRST time, but this TSB is dated 06/12 so that seems... impossible.
And it keeps throwing the code, 3 times in the last 4 days, the light goes out after a few cranks. And the fact it came on in stop&go driving where there isn't time to ride the clutch much due to shifting up and down.
Old Jul 11, 2008 | 04:33 PM
ChevyMgr's Avatar
These programs are added at the factory way before they come out in a TSB or a PI. TSBs have to go through GM legal before they are released to dealers. Many times Technical Assistance will send us the update on a vehicle having the problem, before it is ever released in a bulletin.
Old Mar 15, 2009 | 12:25 AM
xtremekirk's Avatar
i have a consistant problem with my HHR SS, I had the stage kit installed and everything was fine for a month, two days ago I had a misfire take place and then a steady CEL, took it into the dealer and they said it was dirity injectors. They cleaned them and said it was fine. I'm pulling out of the dealership parking lot and it misfires again. I take it to another dealer, have them check over everything from the upgrade kit and verify the tune was correct. They say it was and I leave. Now it throws another light and the turbo is surging under boost, what the hell is it?? could it be the boost control valve???
Old Mar 15, 2009 | 07:04 AM
ChevyMgr's Avatar
Without knowing the code I could give a thousand guesses. If I knew the code I could narrow my guesses to less than twenty. You need to take it to a dealer that will diagnose the code, repair it and then DRIVE it afterward to verify it is fixed, before they put you back in it.
Old Mar 15, 2009 | 08:28 AM
xtremekirk's Avatar
is it possible for onstar to give me the enigne code?
Old Mar 15, 2009 | 05:56 PM
turbofreak's Avatar
yes
Old Mar 16, 2009 | 09:48 AM
mistermike's Avatar
I'm wondering, going forward, what those of us with the turbo upgrade should do in a service situation that requires a reflash? I'd hate to wind up with the ECM being reflashed back to the standard calibration, then be unable to download the GMPP upgrade calibration. It would seem that any significant code changes to the OEM calibration would have to also be applied to the upgrade calibration on a parallel track.
Old Mar 16, 2009 | 09:52 AM
esmarkey's Avatar
I too have wondered about this.... I am hoping that the "flash" is vehicle specific and the VIN number would trigger the upgraded tune, but to be safe I will always remind my service adviser that I have the tune and want it back with said tune, if/when I take my car in for service...
Old Mar 16, 2009 | 03:04 PM
ivtech's Avatar
The number on the upgrade kit instruction is assigned to the VIN when it is re-flashed. I do keep the cover sheet with the number in the glove box just to make sure.
