No boost problem
I am having an issue with my SS. After a few minutes on the road the car won't boost, it will not go over 0 boost. Is there anyone with this issue. I turn the car off and it will work again but only for a few minutes.
I have a few mods: Dejon intake, CIA catless downpipe, borla exhaust. PLEASE HELP............. |
Originally Posted by LMOSHHR
(Post 606789)
I have a few mods: Dejon intake, CIA catless downpipe, borla exhaust. PLEASE HELP............. Are you tuned for any of your mods? If not...the intake alone will throw you into limp mode....mine has been going into limp mode as well because of my Dejon SRI....it hasn't been tuned for it yet |
It could be a lot of things; Does your check engine light come on? It should after a few times going into limp mode. The code should help you figure out where to look next.
Kiss is right remove the Intake, until you are tuned for it. Some (like myself) have not had problems adding an intake after the GMTU, most will still see a code until 2nd tune HPT or Trifecta..... the others are just snake oil, or canned tunes(BSR)
I installed the intake at 10,000 miles, the car has 69,000 miles. Does the low tire pressure indicator have anything to do with LIMP MODE. This problem occured once the indicator came on.
(Post 606834)
So...you've had the Dejon SRI on the car for about 59,000 miles since the car went into limp mode? Also....did it throw any codes at all? |
Not a low tire issue, last week I had the light go on with 26 psi in the tire and still could spool her up. I have loose boost sometimes becasue the bypass sticks open or dosent seat right and it light out until I turn it off. I have had the POS spring replaced 4 times (under warranty so its on the house :)
Originally Posted by BZERKED
(Post 606864)
You hit the nail on the coffin. That is exactly what is happening to my car. It spools, but no boost. The POS spring was the cause of the issue. |
When I finally found a GM tech that was turbo-smart he was telling me that they can stick open from time to time and if you turn it off it comes right back... LOL
I am going to swap it with a Forge unit shortly. Maybe Santa would be a champ and hook me up..... |
(Post 607143)
