Oil Change
My Oil Life says 73% when if I use this should I change the oil.
Thanks, mblandsr (Mike) :twothumbs: |
It will flash a message in the DIC screen to change oil, I usually go to 20%, but have had to let it go till the change oil message pops up.
Some go by milage some go by time, some go by the type of oil they use, Dino or synthetic. In our 2003 Sunfire GT 2.2, I have been consistent at 6 months, 6,000 miles with synthetic oil. 200,000 plus miles and 13 years it still runs great gets 30 mpg and has 145 to 150 psi compression, no oil burn off or oil leaks. Our HHR is at 198,000 miles and still cranking on just fine 150 psi on all 4 cylinders no oil usage and gets 33 mpg fairly consistently |
Oil Change
Thanks Guys.........
mblandsr (Mike) |
You are welcome!
