Oil Change
Old Sep 21, 2015 | 09:11 AM
mblandsr's Avatar
Oil Change
My Oil Life says 73% when if I use this should I change the oil.
Thanks,
mblandsr (Mike)
Old Sep 21, 2015 | 09:36 AM
It will flash a message in the DIC screen to change oil, I usually go to 20%, but have had to let it go till the change oil message pops up.
Some go by milage some go by time, some go by the type of oil they use, Dino or synthetic.
In our 2003 Sunfire GT 2.2, I have been consistent at 6 months, 6,000 miles with synthetic oil. 200,000 plus miles and 13 years it still runs great gets 30 mpg and has 145 to 150 psi compression, no oil burn off or oil leaks.
Our HHR is at 198,000 miles and still cranking on just fine 150 psi on all 4 cylinders no oil usage and gets 33 mpg fairly consistently
Old Sep 22, 2015 | 07:48 AM
mblandsr's Avatar
Oil Change
Thanks Guys.........
mblandsr (Mike)
Old Sep 22, 2015 | 10:29 AM
You are welcome!
Jim's 2009
Maintenance and Upkeep
68
Nov 10, 2013 11:48 PM
badassbowtie
23
May 12, 2013 02:01 PM
fastdogs
Dec 24, 2008 07:57 AM
Black Rose
May 14, 2008 07:44 PM
EL_REY
2.4L Performance Tech
14
Aug 28, 2006 06:53 AM
