Oil Pressure Gauge
Old Aug 11, 2011 | 12:15 PM
BZERKED's Avatar
Oil Pressure Gauge
Has anyone installed a aftermarket oil pressure gauge? I would appreciate any tips where to tap into the block and ideas inside the car too. Thanks - Rob
Old Aug 11, 2011 | 12:50 PM
TurboTechRacing's Avatar
Former Sponsor
There are 3 galley ports on the front and 3 on the rear of the block.
You will need to adapter to go from the metric thread to a standard 1/8NPT:
http://www.turbotechracing.com/produ...8&idcategory=0
Thread out the stock plug and insert this plug, it should then work with any oil pressure kit.
Old Aug 11, 2011 | 09:36 PM
1Panel2NV's Avatar
Short term memory there OP? You made this thread yesterday.
https://www.chevyhhr.net/forums/hhr-ss-45/oil-pressure-gauge-36956/
You can get the adapter cheaper at your local speed shop.
I don't think you can easily get to the galleys on the intake side without taking off the intake manifold. Clearance would be a problem again even if you could. Two are right below the knock sensors and the one in the middle will be close to the throttle body.
Old Aug 11, 2011 | 09:50 PM
bassbase's Avatar
Sweet. I am going to add a matching Sunpro oil pressure gauge to my Sunpro vacuum gauge
Old Aug 12, 2011 | 07:22 AM
bartSS's Avatar
Originally Posted by bassbase
Sweet. I am going to add a matching Sunpro iol pressure gauge to my Sunpro vacuum gauge
yayyy autozone
Old Aug 12, 2011 | 08:02 AM
bad03xtreme's Avatar
I wonder why an Oil Pressure gauge wan't included on the SS models.
Old Aug 12, 2011 | 08:14 AM
bassbase's Avatar
Originally Posted by bartSS
yayyy autozone
Yeah eBay!
I took a look at my block today. What do the galleys look like? Do they look like small round plugs about the size of a nickel with what looks like an allen insert in the middle? I can see 2 under the intake manifold and 3 on the drivers side of the block.
BZERKED
Nov 27, 2012 10:30 AM
dodger542000
Tires & Wheels
Sep 6, 2012 09:14 PM
SimonMci
Aug 27, 2010 10:50 AM
havanetalking
Oct 7, 2008 07:15 AM
2K7 HHR
Aug 24, 2008 08:53 AM
