P0236 Code Help
P0236 Code Help
My HHR SS has the issue with a P0236 code set in the ECM. It will not accelerate or go over 5#'s of boost. I have no SES lite on but the code is set the ECM anyone that has had this code come up ever find a fix? So far the dealer has no answers. Thanks, Jason
Are there official GM directions saying the solution is soldering the wires? My SS is about to go in to get this repaired for the 2nd time - Seems like every 6 months the connectors go.
When I talked to my new dealer (old dealer is gone) he said that they could only solder if directed by GM otherwise I would have to pay for the soldering work.
Gah wish I would've seen this a little while ago, I'm sitting in the waiting room now with the exact same issue. I mentioned a few things including soldering the wires, possibly bracing the IC forward, and making sure nothing is pressing into the condenser or anything. Forgot about the convoluted tubing.
It's weird, both times I've brought the car in for this issue the boost has randomly come back on my way into the dealership, even though the CEL has stayed on. This time, it worked about half the times I gunned it on the way in, the other half it dogged completely.
Later
Allex
If you do a search on here you'l get all the updated notes on the install. There's a very long thread on this that More_hp_More_Tq started up where you can see/read everything we've been saying here. It's stickied in the 2.0L performance section and covers all the info on the GM Upgrade. Just copy n paste the necessary info and bring it to your dealer.
Later
Allex
Later
Allex
Thanks Bill
Later
Allex
Later
Allex
Billy-Bob
